Getting logged out?
Started by PhillyGirl, December 06, 2004, 04:26:13 PM
So you're saying that you are still having the "logged out" problem? I'm not talking about the session verification, or the timeout thing.
Yeah, whenever I come onto the board I am not logged in.  But I don't have to actually enter my user name and password, I just have to hit refresh or open a thread and I'm magically logged in.  I don't know if you consider that a problem or not.  It's not a big inconvenience but at the same time I know the board isn't supposed to work that way.
What's the address you use when you first jump on the board? Or if you're using a bookmark, the address from that.
I finally decided to play with the addresses myself to see if that was a problem. Turns out it is. If you use http://concretefield.com/forum to get to the board it takes you to http://www.concretefield.net/forum. The board considers it's address to be http://www.concretefield.com/forum, so once you click any link from http://www.concretefield.net/forum it will take you to www.concretefield.com/forum.
Confused yet? Try those links and see if it happens to you.
I noticed that if I use just http://www.concretefield.com/forum it takes me to a cached page, with no login (it shows CJSuperPool as the latest registrant). If I add the index.php, it goes to the right place.
You want to add a redirect that pushes both http://concretefield.com/forum and http://www.concretefield.com/forum right to http://www.concretefield.com/forum/index.php?
Quote from: Susquehanna Birder on December 24, 2004, 09:57:20 AM
All done. That should take care of it now.
I edited index.php on the /board directory...and now it points to http://www.concretefield.com/forum/index.php on the redirect.
Is this a glitch in the software, or something else?
The whose online thing, I clicked on it and saw this:
QuoteGuest  03:02:36pm Nothing, or nothing you can see...
Now I'm getting this problem. I have to log in every time. I do have it as 'forever'...but I have to log in all the time.
Maybe I should reset the board as a bookmark and erase the old one?
