Laptop Memory Upgrade
Started by Zanshin, May 03, 2006, 02:24:15 PM
Well, I certainly do that.  And after a year and a few months, it only holds about a 15-20 minute charge.  I'm not sure what the average life span of these things tends to be.  Maybe that's about right.  Guess all I need to know is that I have to pony up for a new one.
Quote from: Cerevant on May 04, 2006, 11:16:49 AM
Let me clarify a few things on the battery life discussion above....
Thanks for the info!
So you're saying that my 2 minutes of battery life is normal? That once it's "dead", I should expect to get a full recharge out of it?
Cerevant
Well, there's a bit more to it than that - obviously all batteries die, we're just talking about what you should do to keep it lasting longer - which is different depending on the battery.
Here's an interesting article on Wikipedia that covers some interesting stuff - apparently temperature can have a pretty big effect as well.
An ad hominem fallacy consists of asserting that someone's argument is wrong and/or he is wrong to argue at all purely because of something discreditable/not-authoritative about the person or those persons cited by him rather than addressing the soundness of the argument itself.
Okay, just popped in another 512 of RAM.  Any idea why my computer would only show me as having 896 meg of RAM, now that I popped 512 on top of the resident 512?  Do I need to do something other than just pop it in?
Father Demon
Quote from: Zanshin on May 08, 2006, 04:04:30 PM
Man, if I had a nickel for every time I've asked that exact question...     :paranoid
The drawback to marital longevity is your wife always knows when you're really interested in her and when you're just trying to bury it.
Quote from: DemonchildrenOnTurf on May 08, 2006, 04:26:45 PM
Are you seeing the 896 in Windows, or in your CMOS setup area?
In Windows, when I go to Start>Control Panel>Performance and Maintenance>See Basic Information about your computer.
And I should probably mention that I don't know what a CMOS setup area is. ;)
When you boot, before Windows starts up, the computer gives you the option to see the "setup" by clicking F2, that's the CMOS area. Somewhere in there you should see the installed amount of RAM. I believe you should also see the correct amount when the PC first boots, as it's doing it's power-on self-test (POST).
I suspect that what your'e seeing once Windows runs is the available memory. Most likely, your laptop shares some of the installed RAM with the video card. It's a typical way to make a lower-cost video display work better - offload the memory requirement for the video onto the overall system memory.
Anyway, it looks to me like your system is pre-allocating 128 mb of RAM for the video functions and reporting the remainder as available. It was probably doing that before (giving you 384 mb of available memory). It's nothing to worry about, since you just pumped in a bunch of extra RAM.
Cool.  I do believe that I did bump up the amount of memory available to the video card.  I'll check that out.  Thanks.
I heart this thread.  You learn things here.
