Week Eight - 2017
Started by PhillyPhreak54, October 26, 2017, 08:21:40 PM
the hit to the head area was bad on flacco but no farging way should kiko be responsible for hitting a sliding qb in this case....flacco was running hard as shtein for the first down marker and went down mad late...id even argue the late slide and the speed he was going at caused the head area to be smashed
they should make a rule that qb's cant slide after five yards....if you are trying to run 15-20 yards to get a first down you should not be allowed to farging slide....if you are simply escaping the pocket and run out of pressure and slide because a linebacker has come up on you then fine
Same...I agree
This whole thing where QBs are treated like pampered princesses is ridiculous.
Quote from: PhillyPhreak54 on October 27, 2017, 12:24:08 PM
It's almost as if they would prefer to be marketing Aaron Rodgers over Brett Hundley.
qb's should definitely receive special treatment...just not running full speed 20 yards downfield
I'm all for protecting franchise quarterbacks especially now that the Eagles appear to have one.
In fact, get flags for Wentz to wear!
as usual you go full republican neanderthal on this. DURRR MORE HITS BRAIN DAMAGE GOOD DURRR
From ESPN
According to the source, the players could decide to all kneel together, and also discussed peeling the Texans decal off of their helmets or raising their fists. However they decide to protest, the plan will be revealed Sunday, the source said.
If they peel the stickers off that will be interesting
They should all take their helmets off to reveal a Klan hood with a Texans logo on it
That's more of a marketing apology to the owner than a protest.
Every player on every team should kneel.  They won't because money means more to them than principle.
Scherff and Williams likely out for WAS today
the racist Indian patch on these jerseys is an extra special touch
if zeke is playing they the best team in the nfc
